(灌水開箱)TEAC UD-H01 ~ 找回聆聽音樂的最初感動
Re: (灌水開箱)TEAC UD-H01 ~ 找回聆聽音樂的最初感動
文章snake0109 發表於 週日 11月 27, 2011 11:55 pm
Description
TEAC UD-HD1 USB audio DAC (digital to analogue converter) is part of TEAC's 2011 reference hi-fi range, designed to get the best sound from your PC, Mac, or any other digital audio source for your hi-fi or headphone amplifier. This DAC is a first for the TEAC brand, a high end design to fill the need to get the most from a computer/Mac/USB digital music as a serious hi-fi source.
Features include high-resolution 32bit/192kHz dual BurrBrown DACs with 192kHz up-conversion, allowing you to "upsample" the sound possible from lower resolution music files.
Digital inputs include USB, coaxial and optical with RCA and balanced XLR outputs (quite a boon at the price!) along with a headphone output jack with it's own volume control. The latter is a dedicated internal design, built to drive many models of high end headphones including models such as the AKG Q701, Grado GS1000i, or Sennheiser HD800. Having said that, you can use a separate additional headphone amplifier if you wish with the UD-HD1 for even better sound.
Features
- USB Audio Class2 High-speed Input from PC/Mac (Tenor 8802)
- 32-bit/192kHz Dual D/A Converters (BurrBrown 1795 x 2)
- Up-conversion to 32bit/192kHz
- Supports Asynchronous Transfer Mode
- Toroidal-core Power Transformer
- Detachable AC Socket
- Headphone Out with Volume Control
- Aluminium Front Panel
- Available in Silver or Black
Specifications
- USB Input: x 1 (USB 2.0)
- Digital Audio Inputs: x 2 (Coaxial, Optical)
- Balanced Audio Output: x 1 (XLR, 1=GND, 2=Hot, 3=Cold)
- Audio Output: x 1 (RCA)
- Headphone Out: x 1 (6.3mm)
- Input Signal Sampling Rate: 44.1kHz, 48kHz, 88.2kHz,
- Operation: 120V AC, 60Hz (US), 230V AC, 50Hz (EUR)
- Dimensions (W x H x D): 215 x 55 x 215 mm
snake0109
註冊時間: 週五 7月 10, 2009 11:05 am
文章snake0109 發表於 週一 11月 28, 2011 12:09 am
Key Features
USB音頻 Class2的高速輸入的PC / MAC USB Audio Class2 High-speed Input from PC/MAC
(期限8802) (Tenor 8802)
32-bit/192kHz的雙 D / A轉換器 32-bit/192kHz Dual D/A Convertors
(BurrBrown 1795 × 2) (BurrBrown 1795 x 2)
上轉換到32bit/192kHz Up-conversion to 32bit/192kHz
snake0109
文章jeubow 發表於 週一 11月 28, 2011 11:29 am
好...好多英文字,我還以為是廣告機XD,網兄何不將問題直接詢問代理,應該會有更明確的說明,依這篇產品規格特點來看,裏頭並沒有我們想要的答案。
jeubow
文章: 360
註冊時間: 週六 6月 14, 2008 12:56 pm
文章snake0109 發表於 週二 11月 29, 2011 7:36 pm
Teac集團為Esoteric的母公司,這款UD-H01數類轉換器在海外發表後,以高規格的功能與平實的價格獲得各界高度注目。不僅能用於Windows系統(Windows 7/Windows Vista/Windows XP 32bit),也支援Mac系統(OS X 10.6.4以上,Snow Leopard/Lion),以USB連接採非同步傳輸模式,透過內建的Tenor 8802接收晶片,最高支援24bit/192kHz。而核心的DA晶片則是左右聲道獨立各一的Burr-Brown PCM1795,以Dual Mono的方式作32bit/192kHz的處理,最終能將音樂訊號升頻至192kHz輸出。
:ya: :ya:
snake0109
文章altissimo 發表於 週二 11月 29, 2011 9:13 pm
snake0109 寫:Teac集團為Esoteric的母公司,這款UD-H01數類轉換器在海外發表後,以高規格的功能與平實的價格獲得各界高度注目。不僅能用於Windows系統(Windows 7/Windows Vista/Windows XP 32bit),也支援Mac系統(OS X 10.6.4以上,Snow Leopard/Lion),以USB連接採非同步傳輸模式,透過內建的Tenor 8802接收晶片,最高支援24bit/192kHz。而核心的DA晶片則是左右聲道獨立各一的Burr-Brown PCM1795,以Dual Mono的方式作32bit/192kHz的處理,最終能將音樂訊號升頻至192kHz輸出。
:ya: :ya:
不知道板子上哪個元件是負責把訊號提升為32bit的呢?
希望那位大大能開釋一下 :haha:
altissimo
文章: 147
註冊時間: 週二 7月 29, 2008 12:11 am
文章mlnaml 發表於 週三 11月 30, 2011 1:57 am
日本的原文是說採用da晶片是"能處理32bit/192k hz"的PCM1795
沒有提到32bit喔,而且usb接收晶片是24bit/192k hz
輸入規格也是16/24bit
整篇文章都沒有提到"把訊號提升為32bit"
mlnaml
文章: 458
註冊時間: 週四 9月 10, 2009 12:13 am
來自: 國立光華(商場)大學
文章fychen 發表於 週三 11月 30, 2011 12:16 pm
各位網友您好,小弟的 TEAC UD-H01 或 ILOVETW,當使用非同步 usb 192/24輸出時,(輸入為一般mp3或無損的wav),不論使用甚麼播放軟體(itune,mediaplayer)都會-當掉, 卡住,跳掉或播播停停,請教各位網友您們會不會發生?若會是否有解決之道?小弟在另一論壇發文但討論者不多,這裡高手應該很多,請您提供意見,小弟非常感激,謝謝,因為音樂聽一半停下,感覺非常不好, 又不想調成96/24
fychen
註冊時間: 週二 1月 18, 2011 9:46 am
文章nawussica 發表於 週三 11月 30, 2011 12:42 pm
請問"非同步"是否已安裝驅動程式
風之谷的娜烏西卡
有沒有M3修不好的八卦
nawussica
文章: 42
註冊時間: 週三 11月 14, 2007 1:01 am
來自: 風之谷
文章fychen 發表於 週三 11月 30, 2011 1:45 pm
nawussica網友您好,小弟忘了說明電腦用 win7/32,非同步驅動程式已安裝,並在聲音內容設為192/24,且測試聲音正常 ,謝謝網友答覆
fychen
文章fychen 發表於 週三 11月 30, 2011 3:15 pm
各位先進網友,不好意思,小弟再說明一下,就是TEAC H01在win7的 192/24非同步模式下,驅動程式安裝ok,聲音內容測試也ok下,請問網友會不會無預警的-卡住或當掉或播播停停,請網友告知您的 TEAC H01會不會?? 謝謝
fychen
文章fychen 發表於 週五 12月 02, 2011 9:24 am
感謝勝旗公司李先生的建議,目前使用foobar2000+wasapi,頻率會依輸入格式跳動,不會只定在192/24,就不會當了,但播放純192/24格式時,buffer length調成約 150ms ,曾有雜音出現,因有網友改成 1000ms,會改善,不過勝旗公司李先生也好像正在與原廠解決這個問題,希望有解..
由這個現象小弟有一點迷失, 是否像 itune播放程式, 當電腦預設為192/24時,不論音樂格式為何均會升頻至192/24播放嗎 ? ? ? ? 是否在升頻過程時就容易當 ??? 有網友能解惑?請告知非常謝謝
fychen
文章AudiChang 發表於 週五 12月 02, 2011 10:43 pm
fychen 寫:感謝勝旗公司李先生的建議,目前使用foobar2000+wasapi,頻率會依輸入格式跳動,不會只定在192/24,就不會當了,但播放純192/24格式時,buffer length調成約 150ms ,曾有雜音出現,因有網友改成 1000ms,會改善,不過勝旗公司李先生也好像正在與原廠解決這個問題,希望有解..
fychen大你好,
先說明一下,我在拿到TEAC UD-H01裝完driver (Win7 64bit),
聽了一兩個鐘頭就blue screen了,馬上就反映給勝旗了。
隔天試沒有發生blue screen,但是用foobar2000播放,這個application會擋掉且無法kill掉。
最重要的是,你按pause鍵,再繼續播放時,會變成雜音(似乎是頻率跑掉了?!)。
反映給勝旗了,也跟他們的工程師通過幾通電話。
最後有跑了一趟勝旗,跟這位工程師(不知道是不是李先生? 但是只有一位。)一起debug。
最後結果是,使用KS or WASAPI播放均會發生雜音現象。
在Win7 64/32 bits 及 Vista 32 bit OS下都試出問題。(自己在家裡用XP 32到是沒發聲雜音,但是也blue screen一次。)
當天勝旗有請USB Tenor 8802晶片商邱先生過來,
有告知及試出問題來,他們已經帶回一台去debug。
但是已經經過一星期多了還是沒聽到結果。
下禮拜我會再去問一下。
還有,當你電腦預設成192/24時,不是用KS/WASAPI播放時,都會被軟體升頻為192K。
這時播放是沒有問題的。
另外,我用Coaxial輸入,聽192k的原生音樂檔時,
這台機器會一直跳動在選擇輸入頻率,無法正常播放。
不知道有無大大小弟一樣的?
AudiChang
註冊時間: 週一 3月 21, 2011 10:38 pm
文章fychen 發表於 週五 12月 02, 2011 11:40 pm
AudiChang大您好,
謝謝您的答覆,原來你早就反應了, 其實我原來也會藍色死當 ,後來把onboard 的音效卡關了才沒再藍色死當,
不過想請問你,小弟現在只要電腦預設192/24,用itune播放無損wav(cd轉的),就會卡住,不知你的會不會?
另外,我的另一台ILOVETW,也會卡住,它們的usb晶片是相同的,不過若電腦改為96/24就好了,您有空可試試看,是否在192/24使用itune會卡住,但調成96/24就又好了,先謝謝你的努力,也希望勝旗公司能解決這衝到的問題
fychen
文章AudiChang 發表於 週四 12月 08, 2011 12:39 am
今天有跟Tenor的副理通過電話,
看來還再查原因。
fychen大的問題也一併告訴他(我自己還沒try! Sorry!),請他試試看。
所以暫時還是無解囉!
AudiChang
文章jeubow 發表於 週四 12月 08, 2011 6:40 pm
我是用keces mus-155 usb轉同軸 > ud-h01,mus-155最高只對應到96khz,之前在別台dac顯示是沒問題的,但是用在ud-h01就抓不訊號了,當然,192khz就不用說了,聆聽的wav檔案是24bit/44.1 or 48khz,96khz以上的檔案真的有夠大,期待代理及原廠能早日說明解決之道囉。
jeubow
文章: 360
文章smallppp 發表於 週六 12月 10, 2011 6:16 pm
AudiChang 寫:
fychen大你好,
但是已經經過一星期多了還是沒聽到結果。
下禮拜我會再去問一下。
這時播放是沒有問題的。
不知道有無大大小弟一樣的?
個人系統是 win7 x64 + foobar 1.1.6 ,
當使用非同步usb(已安裝x64驅動)時 ,不管是ds還是wasapi輸出,都會有cpu使用量幾乎100%的現象,導致系統lag
換過幾個主機板的usb插槽都一樣,但是沒有藍屏的問題。
主機板同軸輸出若是96/16 or 96/24 都會產生嚴重lag的聲音,其他正常。
目前只能同軸慢慢用==
smallppp
文章: 14
註冊時間: 週日 11月 25, 2007 11:32 pm
上一頁
正在瀏覽這個版面的使用者:沒有註冊會員 和 128 位訪客
