Model NO. X7
ETA: 2015
M.S.R.P:   $699 in U.S
OS: Custom OS based on Android, can supports some third party APP from our website.
Weight: Less than 300g
Size: thickness will be almost the same as X5 , the other size is almost the same as 5 inch Android Phone.
Screen: 3.5 inch ~ 4.3 inch Full Touch Screen. To be decided.
Key layout: Full touch control+ Bottoms+ Volume Knobs
Output power: > 300mW/32 ohms, Power supply: +/- 6V ~ +/-11 V  . To be Decided.
Playtime: 10 hours
Battery: Build in Battery.
Data transfer: USB 2.0 ( Micro USB), WiFi
Blue Tooth: YES , supports APTX
DAC chip: ESS9018 , not ESS9018M2K, The ES9018 includes 8 channels DAC which means it is equal to 4 X ESS9018M2K
Enclosure: Metal
Build in memory: To be decided.
Extra Memory: Micro SD slot X 2
Accessory : Leather Case X 1,  Micro USB cable X 1,
翻譯中文(翻錯請指正)
Fiio X7
預計上市時間:2015
售價:$699
作業系統:Android
重量:少於300克
體積:厚度約同X5,大小約同5吋Android手機
螢幕:3.5吋~4.3吋全觸控螢幕
按鍵:全觸控、底座和音量調節鈕
輸出功率:300毫瓦/32歐姆
電源供應:+/- 6V ~ +/-11V 待決
播放時間:10小時
電池:內建
資料傳輸:USB2.0(micro USB)、WiFi
藍芽:有,支援APTX
DAC晶片:ESS9018,非ESS9018M2K,ESS9018含8通道DAC等於4個ESS9018M2K
機殼:金屬
內建記憶體:待決
外插記憶體:Micro SD x 2
附件:皮套x1 、Micro USB線x1
消息來源:
http://www.head-fi.org/t/713735/fiio-x7 ... -dream-dap
