MP4,MP3影音轉換 (多國語言 ):Angel Video Converter v1.7
文章E007a 發表於 週三 5月 28, 2008 8:53 am
Angel Video Converter is the choice for all-in-one video and audio conversion program. It supports most of video formats including H264(MPEG-4 AVC),VCD,AVI,WMV,MP4,MOV,3GP,3G2,ASF and audio file formats like MP2,MP3,WMA,AAC,M4A,WAV,AC3 and more. It can also extract music from video media and vice versa.
Angel Video Converter supports all of the popular multimedia devices including PSP, iPod, Apple TV, MP4 player, XBOX, PS3, Zune and mobile phones. Select the multimedia files, the intended devices or formats, and hit "Encode" to convert multimedia files to the right format for your intended devices.
For advanced users, you can just answer a few easy to follow questions to convert your media files to the exact specifications.
Download:
http://www.soft-music.net/AVConverter.torrent
E007a
註冊時間: 週三 5月 28, 2008 8:44 am
文章ben_chien 發表於 週三 5月 28, 2008 9:15 am
Unit Price: TWD 914.30 / USD 29.99 [Volume discount prices]
Tax/VAT may be added for certain countries. Exact details are provided before the order is completed.
Delivery:License key by e-mail
不知道是不是發錯版了??
如果要分享也分享個完全免費的(不是透過快樂檔)
http://www.erightsoft.com/SUPER.html
SUPER © "The Encoder" is the fastest and simplest tool to encode full
length movies to any other format without any time or function limitation.
NO trial or evaluation version of SUPER © but one unique
Free to download and Free to use fully working version.
# SUPER © IS UNIVERSAL as it supports a wide variety of input/source file format to play
or encode (to & from) without any additional third party software.
Supported input source file formats are:
- Image Sequence: jpg, pgm, png, ppm (with sequentially numbered-ONLY filenames)
having the same filename numbered-ONLY format. Example: 0001.jpg --up to--> 0999.jpg
note that this format will NOT work name_0001.jpg --up to--> name_0999.jpg (take out name_)
- Video format: 3gp/3g2(Nokia,Siemens,Sony,Ericsson), amv, asf, avi(DivX,H263,H263+,H264,XviD,MPEG4,MSmpeg4...), dat,
fli, flc, flv, m2t, mkv, mpg(MPEG-I,MPEG-II,VCD,SVCD), mov(H263,H264,MPEG4,SVQ..), mp4(H263,H264,MPEG4..), nsv, ogg,
qt, rm, ram, rmvb, str(Old Play Station), swf(Flash), ts(HDTV), viv, vob, wmv
- Audio format: aac, ac3, amr, mmf, mp2, mp3, mp4, mpc, ogg, ra, wav, wma
- AviSynth Script Files: avs. Let you specify advanced encoding commands using AviSynth scripts!
# SUPER © supports the conversion (encoding both ways, to & from ) of ALL the listed formats.
To list few examples:
o drag & drop any Audio file or even any VIDEO file and EXTRACT the AUDIO part by converting it to
aac, ac3, amr_nb (for ring tones), amr_wb, mmf (for ring tones), mp2, mp3, mpc (MusePack), ogg, wav, wma formats.
o Sequence Of Images converter Convert any input video format to a sequence of still images in jpg, pgm, png, ppm format.
Convert jpg, pgm, png, ppm sequentially numbered filename images to any other video format.
jpg, pgm, png, ppm input image files must have the same filename numbered format. Example: 0001.jpg --up to--> 0999.jpg
o Mobile phone 3GP converter Convert any input video format to 3GP. Convert a 3GP file to any other video format.
o Mobile phone 3G2 converter Convert any input video format to 3G2. Convert a 3G2 file to any other video format.
o PocketPC converter Convert any input video format to a PocketPC file. Convert a PocketPC file to any other video format.
o iPod & iPod 5.5G converter Convert any input video format to an iPod/5.5G file. Convert an iPod/5.5G file to any other video format.
The rendered iPod/5.5G files are created using the most advanced video codecs H.264/AVC and MPEG-4 format.
To copy a DVD (that you legally purchased) into a valid iPod/5.5G format, we recommend that you also use the best
available DVDDecrypter to decrypt the entire DVD and copy the VOB files to your HardDisk in order to encode
them with SUPER ©. Note that DVDDecrypter is also a Freeware.
o PS3 & PSP converter Convert any input video format to a PS3/PSP file. Convert a PS3/PSP file to any other video format.
The rendered PS3/PSP files are created using the most advanced video codecs H.264/AVC and MPEG-4 format.
To copy a DVD (that you legally purchased) into a valid PS3/PSP format, we recommend that you also use the best
o Zune converter Convert any input video format to a Zune file. Convert a Zune file to any other video format.
The rendered Zune files are created using a fully compatible WMV7/8 and WMA format.
To copy a DVD (that you legally purchased) into a valid Zune format, we recommend that you also use the best
o Nintendo DS converter Convert any input video format to a Nintendo DS file. (.dpg)
The rendered Nintendo DS files are created using a fully compatible DPG format.
To copy a DVD (that you legally purchased) into a valid Nintendo DS format, we recommend that you also use the best
o VCD converter Convert any input video format to MPG-VCD. Convert an MPG-VCD file to any other video format.
The rendered MPG files are VCD-standard strictly compliant and "NERO burning" compatible. They are seamlessly
accepted by NERO to burn without any additional process and produce a CD playable on most stand alone players.
o SVCD converter Convert any input video format to MPG-SVCD. Convert an MPG-SVCD file to any other video format.
The rendered MPG files are SVCD-standard strictly compliant and "NERO burning" compatible. They are seamlessly
o DVD converter Convert any input video format to VOB-DVD. Convert a VOB-DVD file to any other video format.
The rendered VOB files are DVD-standard strictly compliant and "TMPGEnc DVD Author" compatible. They are
seamlessly accepted by the "TMPGEnc DVD Author" which will add the necessary Menu, create the
additional .bup and .ifo files, rename/split the rendered VOB file to Vts_xx_x.vob before burning to DVD.
o AVI converter Convert any input video format to AVI. Convert an AVI file to any other video format.
The rendered AVI files are created using a wide variety of codecs H.264/MPEG-4/DivX/XviD/H.263... together
with AAC, ac3, mp3, mp2 or wav audio.
o MP4 converter Convert any input video format to MP4. Convert an MP4 file to any other video format.
The rendered MP4 files are created using a wide variety of codecs H.264/MPEG-4/DivX/XviD/H.263... together
with AAC, AMR, wav audio. They are fully playable on QuickTime7.
o MOV converter Convert any input video format to MOV. Convert a MOV file to any other video format.
The rendered MOV files are created using a wide variety of codecs H.264/MPEG-4/DivX/XviD/H.263... together
o ASF converter Convert any input video format to ASF. Convert an ASF file to any other video format.
o FLV converter Convert any input video format to FLV. Convert an FLV file to any other video format.
o MPG converter Convert any input video format to MPG. Convert an MPG file to any other video format.
o OGG converter Convert any input video format to OGG. Convert an OGG file to any other video format.
o WMV converter Convert any input video format to WMV. Convert a WMV file to any other video format.
o GIF converter Convert any input video format to Animated GIF format.
o convert AviSynth script files (.AVS) to any other video format.
o convert VCD (.DAT) files to any other format. (Also with Lossless Direct Conversion to MPG VCD-Compliant )
o convert Flash (.FLV) files (similar to Google/YouTube video) to any other format.
o convert Matroska (.MKV) files to any other format.
o convert QuickTime (.QT) files to any other format.
o convert RealMedia (.RM .RAM .RMVB .RA) files to any other format.
o convert Old.Play.Station (.STR) files to any other format.
o convert ShockWave Flash (.SWF) files containing FLV or VP6 video codec to any other format.
o convert HDTV (Transport Stream .MPG / .TS / M2T [EXCLUDING BLURAY VIDEO]) files to any other format. (Also with Lossless Direct Conversion To VOB)
o convert VivoActive (.VIV) files to any other format.
o AutoMode to convert any input video format to VCD, SVCD, DVD Standard Compliant formats.
o "Direct Stream Copy" mode to render exact quality when the same video/audio codecs of the source file are to be used in the output file.
o Play all of the above file formats with SUPER ©
o Play or Save on your Disk the Internet Media Streams like: mms:// rtsp:// http://
o Play Images (bmp, dib, fax, jpg, png, rle, tif, wmf) using Win2K/XP Microsoft Windows® resources.
礙於版面,有些功能請自行到官網參考...
由於官網頁面列出功能太多,
所以提供官方下載連結
下載連結:http://www.erightsoft.org/GetFile.php?SUPERsetup.exe
萬物皆漲,我很不爽
ben_chien
註冊時間: 週五 2月 22, 2008 10:21 am
來自: 另一個地球〈只有我與我的PC〉
正在瀏覽這個版面的使用者:沒有註冊會員 和 138 位訪客
