ACS T1 Custom Made Triple Driver Earphone Monitors
文章freakpower 發表於 週三 12月 16, 2009 8:59 am
Model: ACST1
Manufacturer: ACS
The T1 from ACS represents the pinnacle of in-ear monitoring. Its three balanced armature drivers work in perfect symphony to create an incredible breadth of sound with amazing definition.
A single treble driver provides the perfect highs to pick out the details in any composition while a combined mid-range and bass driver unit gives the benefits of separation with a single physical output channel.The mid-range driver gives perfect clarity where it's most needed, ensuring that this most active range can be delivered with the body and deifinition it deserves whilst keeping it clean and free from bleed. The bass driver creates smooth and balanced tones in perfect harmony with its companion drivers completing a full-bodied and unbiased reproduction that conveys incredible body and detail.
The T1 IEM is supplied with Kevlar™ reinforced cable as standard. Available in a variety of colours, this high performance cable reduces noise generated by motion-induced friction and is far stronger than standard cable to cope with the most demanding environmets. Please note silver and graphite cable finishes are now discontinued. Finished with the Neutrik™ right-angled 3.5mm connector, the T1 cable configuration gives performance befitting our flagship IEM.
How do we custom fit?
All ACS custom-fit products require an impression of your ear for us to work from. Having an impression taken is a quick and painless process that takes less than 10 minutes to complete. One of our network of audiologists will first examine your ear to ensure there is no excessive wax, then a foam plug is applied to create a seal in front of your eardrum. Finally, a soft silicone impression material is injected into the ear and allowed to set for 5 to 8 minutes before being gently removed.
Where can I buy ACS products?
ACS products are available from a nationwide network of Audiologists as well as directly from us at our offices in Banbury. You'll need to make an appointment to have impressions taken which will then be sent on to us to allow us to manufacture your custom-fit products. With over 200+ Audiologists who accept ACS vouchers you have plenty of choice. To find your nearest Audiologist see the complete list on our Find A Dealer page. Please note that production time is always dependent upon orders received. The skills and experience involved in making our hand-crafted products are not acquired overnight so employing more staff, whilst increasing our labour force, does not bring an immediate reduction in production time.
AMP3 and ACS is an incredible combination.
People buy MP3 Players and earphones from Advanced MP3 players because they want the best. To give you the best available, AMP3 have joined forces with ACS to provide what could be the most comfortable and best sounding earphones available. AMP3 will provide buyers with a unique Custom by ACS voucher. This can then be exchanged at any ACS approved audiologist in the UK. From there you will get the full ACS experience and you are on your way to a future of the highest quality music playback.
SHURE SE530PTH + 5800 XpressMusic
freakpower
註冊時間: 週一 12月 07, 2009 1:10 pm
正在瀏覽這個版面的使用者:沒有註冊會員 和 250 位訪客
